rear door adjustment
Old Jan 12, 2009 | 09:01 AM
rm49's Avatar
Default rear door adjustment
My 2005 CRV rear door does not close tight. After closing the door, I can push another 1/4 inch before the door seems fully closed. The rear dome light and dash warning light flashes when driving. This has only recently started to be a problem. (61K miles) I am pretty handy, have loosened and tightened screws on latch, but does not help. Is there something else i can try before bringing it in to mechanic?
Old Jan 12, 2009 | 11:48 AM
Default RE: rear door adjustment
welcome to the forum, have you tried to adjust the latch in the door. have you removed any spacers in the loop catch on the frame, would it be possible the latch catch in the door is worn. Is there an adjustment on the hinge portion of the door or loose and slipped down a bit, or cracked on the frame side.
tommyleea
Mar 25, 2014 09:20 PM
keglerking
Nov 11, 2008 02:41 PM
keglerking
Nov 11, 2008 02:37 PM
keglerking
Oct 28, 2008 09:38 AM
Loodvig
Dec 31, 2006 11:36 AM
