Running lean causes and MAP/MAF sensor location 2006 CRV SE
Old Jul 11, 2022 | 06:54 PM
Mr.Black's Avatar
Default Running lean causes and MAP/MAF sensor location 2006 CRV SE
This should be a fairly straightforward one.
1. My 06 CRV is running lean and I need causes to look for.
2. I need the location of the MAF or MAP sensor whichever it may have. (Pictures are best as I am mechanically retarded.) Tried Google, it's completely useless. Only shows the wrong year crv, accord and civic.
Old Jul 11, 2022 | 07:49 PM
All the air the engine takes in goes through the MAF right at the throttle body.
Do you have a scan tool? You can replace a bunch of stuff and find out you have an exhaust leak.
Old Jul 12, 2022 | 11:37 AM
Mr.Black's Avatar
I do have a cheap scan tool, I'm getting p0420. I'm trying to eliminate the small simple things like exhaust leaks, dirty sensors, clogged pcv valve etc before having to sell a kidney for another new cat and set of o2 sensors.
I've addressed every known leak in the exhaust I could find. The only place I haven't been able to check is the front of the manifold pipe. The cat and sensors are new, (the dealership installed those).
Old Jul 12, 2022 | 11:56 AM
If the rear O2 sensor is in good working order and there are no leaks you have a bad cat. Sorry but you will be wasting your time trying to fix this problem by fixing something else.
If something else needs fixing that is fine but don't expect it to make your cat to work.
Old Jul 12, 2022 | 04:41 PM
Mr.Black's Avatar
yeah, I'm coming to that conclusion. I wanted to avoid it at all cost but I'm willing to bet the dealership put in one of those 100$ cats that **** the bed within 90 days. So unfortunately I'm looking at replacing the cat. I'm still not really understanding why it's running rich or seems to be.
cre2004
Aug 31, 2021 06:00 AM
Henrique Gomes
Sep 8, 2020 12:14 PM
Alex Zuidema
Jun 21, 2017 07:25 PM
axe
May 5, 2014 02:02 PM
speedchaser43
Jul 10, 2008 06:41 AM
