Shift solenoid valve A
Old Jan 17, 2024 | 05:00 PM
Jlabbe222's Avatar
Default Shift solenoid valve A
I have a 2012 Honda CRV EX. I have a fault code PO752. Shift solenoid valve A stuck on. I’m told the P means it’s a performance issue. Meaning the valve is stuck probably with some kind of debris. I plan on removing and checking the valve. So far I can’t find where it is located on the 2012. If anyone has a good diagram of the location where it’s located it would be greatly appreciated.
Old Jan 17, 2024 | 08:49 PM
You would do well to test the resistance of the solenoid first. If you do need to replace it you might want to do it all.
RBrooks828
Sep 8, 2020 04:03 PM
loganschambers12@
May 4, 2020 02:45 PM
GregD11
Jan 8, 2017 06:17 PM
terrynbama
May 30, 2015 10:56 AM
