Shift solenoid problems
Old May 19, 2015 | 03:11 PM
terrynbama's Avatar
Question Shift solenoid problems
I have a 99 Civic EX. I am getting the flashing D4, my scanner gives me a P0758 code.(shift solenoid B) I've checked the continuity of the wires from the solenoid to the ECM, everything checks out OK. Tested the valve by applying 12v, OK. I've even purchased a new valve set. No better than the original.
I have two ECM's and I get the same results with both.
I can clear the codes, reset the ECM by disconnecting the battery and the instant I turn on the ignition switch, the D4 begins to flash. If I check the codes, I GET THE P0758 again, I haven't even started the engine yet.
If I disconnect the connector to the solenoid, I get a P1753 code(Torque converter solenoid valve circuit.
I just don't have any idea which way to go from here. The tranny doesn't slip at all and everything else works great. What can I do?
Old May 30, 2015 | 10:56 AM
terrynbama's Avatar
Default solved
U have solved the problem. I tried rerouting the wires and everything was solved. That indicated broken wires inside the insulation. I then replaced the wire involved about two feet back from the connector. Now all is well.
kentuckyfisherman
Jan 5, 2014 01:15 PM
LX07Pearl
Jun 5, 2013 03:16 PM
drizzt3434
Jul 7, 2006 07:39 AM
speedetec
Jun 8, 2006 12:28 PM
crudntertainment
Apr 4, 2006 03:48 AM
