Trans fluid change on 2009 CRV
Old Jul 24, 2011 | 11:03 AM
AL52818's Avatar
Default Trans fluid change on 2009 CRV
Hello. Question: I am an amateur wrench turner who has been using the following method for years when I change my trans fluid. First, I find out the total capacity of the tranny, converter included, then, I find out how much the pan itself holds. Next, I do some math. on these figures and figure out that if I just drain the pan X number of times, drive the car for about a week to allow the fluid in the pan and converter to mix, then repeat the process Y number of times, I will get Z % of the total fluid changed. For example, on my 2009 CRV, I have to change the fluid in the pan about 12 times to get about a 98 % total fluid change. The only drawback is the disposal of the 30 or so quarts of fluid when finished. I have had great luck with this system for a long, long time. Any comments or critiques greatly appreciated. Now for my question: Does anyone know if the CRV uses a transmission fluid filter and is the drain plug on the tranny accessible without the need to put the car on jack stands ? Diagrams would be much appreciated if possible; I believe someone sent me diagrams on the cabin filter for this vehicle which were invaluable. Thanks in advance for your response. AL
Old Sep 3, 2012 | 03:42 AM
roz2477's Avatar
a great article contain many information like the person like me...thanks for publish this one....Nice article,real estate lawyer brooklyn ny
i appreciate for putting this together! “This is obviously one great post. Thanks for the valuable information and insights you have so provided here. Keep it up!”
papasloane
May 14, 2023 07:22 PM
MaineDoc
Apr 28, 2015 07:58 PM
jrice76
Nov 1, 2010 10:56 AM
fjpthree
May 6, 2010 06:34 AM
donnief150
Apr 24, 2010 10:48 PM
