Water coming in from the sunroof
Old May 9, 2010 | 09:17 PM
kp2001's Avatar
Default Water coming in from the sunroof
Hi!
I'm new to this forum. Have a quick question about our 2007 CR-V.
My wife took it to a "no-touch" car wash today. She noticed that while she was going through the line, she got a bit of water leaking in from the sunroof. It wasn't much, just a few drops, but we are wondering if it's normal.
Given the high water pressure, I personally wouldn't be surprised if we got a little water like that, but she would like to know if it's a problem to be addressed.
Thanks!
Old May 11, 2010 | 05:54 AM
it may be a problem starting. Should not leak. check for ware, cuts, plugged drain, loose drain hose, cracked tray or drain area.
Old May 13, 2010 | 01:28 AM
kp2001's Avatar
Thanks for the useful info! I will definitely have it checked soon.
Old Jun 15, 2010 | 02:13 AM
robj6767's Avatar
My mechanic, who also happens to be my brother, always uses silicon products to fix leaks like that.
Old Jun 26, 2010 | 01:41 AM
jendra's Avatar
Water combing in from the sunroof Should not leak. check for ware, cuts, plugged drain, loose drain hose, cracked tray or drain area,also a advice mechanic they give a proper reason for that.
lilpig
May 4, 2014 07:14 PM
Rich0591
Sep 9, 2009 03:33 AM
JRMCLENDON
Jan 6, 2007 07:03 PM
JRMCLENDON
Dec 3, 2006 05:44 PM
tdfaile
Sep 7, 2006 06:46 PM
