Podenco |
05-09-2016 10:56 AM |
Water temperature
I recently had an engine head change along with some other repairs and since then my water temperature indicator has been acting weird. Prior to repairs, if was fairly rock stable at about the midpoint on the normal temp range. Since repairs, it will sometimes go almost all the way to the red line and then quickly drop, and this is within about 100 yards of driving, to midpoint. I do not believe coolant/water can change temperature that fast. Would it be a sensor problem? Otherwise, the car is running fine and does not really seem to be running hot.
