Water temperature
Old May 9, 2016 | 10:56 AM
Podenco's Avatar
Default Water temperature
I recently had an engine head change along with some other repairs and since then my water temperature indicator has been acting weird. Prior to repairs, if was fairly rock stable at about the midpoint on the normal temp range. Since repairs, it will sometimes go almost all the way to the red line and then quickly drop, and this is within about 100 yards of driving, to midpoint. I do not believe coolant/water can change temperature that fast. Would it be a sensor problem? Otherwise, the car is running fine and does not really seem to be running hot.
Old May 10, 2016 | 07:04 PM
Thermostat is most likely bad.
Old May 12, 2016 | 03:55 PM
Podenco's Avatar
Default Yep ...
Good guess! It was indeed the thermostat. It was rapidly increasing in the problem and I took my car into the dealership. Who knew it would be a $250 charge. I remember the days of picking up a cheap thermostat at the autoparts store and putting them in myself! Apparently, unrelated to the prior head work.
Old May 15, 2016 | 09:22 AM
I have put in new thermostats and a week later they fail,fun x2.
Earthcritter71
May 22, 2011 07:55 PM
Earthcritter71
Apr 27, 2011 12:35 AM
Munns86
Nov 3, 2010 01:48 PM
rduggan3
Feb 8, 2009 08:18 AM
peterturon
Nov 28, 2007 04:25 AM
