-   CR-V Forum (https://hondaforum.com/forum/cr-v-forum-13/)
-   -   Why 2024 Honda CRV has no engine cover? (https://hondaforum.com/forum/cr-v-forum-13/why-2024-honda-crv-has-no-engine-cover-17089/)
theateist Jan 2, 2024 05:12 PM
I purchased 2024 Honda CRV and discovered it does NOT have upper engine cover. All my previous cars had always an engine cover. Is this standard for Honda to not have engine cover? If yes, do you recommend to buy one or is it waste of money?
grcauto Jan 2, 2024 06:00 PM
Did it have a cover when you checked it out before buying?
theateist Jan 2, 2024 06:06 PM
Just before I drove from the dealership I opened the hood and there was no engine cover. I told that to the sales person but he said it doesn't come with one. But, when I left I thought maybe it should come with one anyway. Therefore, I'm asking here if someone has same car or any any insight.
Just Ducky Jan 2, 2024 08:55 PM
Don’t Look Up
My ‘22 has an engine cover and from photos I have seen it appears your ‘24 does as well. Mine is attached to the underside of the hood/bonnet. It is a manufactured part that is formed to fit over the bulk of the engine compartment when the hood is closed. It is made of a sound deadening material similar to “hush mat”. Sound deadening is the non-aesthetic function of an upper engine cover.
IMO the engineering, organization and attention to detail found under the hood of your CR-V should not be hidden by a piece of plastic.
YMMV
theateist Jan 2, 2024 09:42 PM
Can you share the link to those images? I actually found my model on youtube
and it's shown they don't have the engine cover. But, I don't know if that the case or it was removed prior to shooting the video for review purpose.
Just Ducky Jan 2, 2024 10:21 PM
Secret Squirrel
Since you divulged the model (EX-L) it is possible that the lower trim levels may not have that insulation. Mine is a Hybrid Touring and it does.
Here is a link to a dealer with photos:
https://www.visaliahonda.com/new-Vis...RS6H5XRE048287
The ‘24 Hybrid obviously does however at this same site there is photo of a ‘24 EX and it does not. I did not research it ad nauseam for you due to LOI.
If you open your hood and look you will know. If the answer is no, one could order one for the higher trim and install it.
Out
Bubbalou88 Jan 3, 2024 05:51 AM
My 2024 CR-V EX came with it. I would go check others and get the dealer to provide it
I was wrong! I guess I was remembering my wife’s 2013 Accord. My 2024 CR-V EX Does nt have and engine cover
theateist Jan 6, 2024 06:40 PM
I went to a few dealerships again and checked EX, EXL and Hybrids. All except Hybrids do NOT have engine covers. Why is this trim based? It's like having fuse box cover - it'a part of the car and not an accessory!
Just Ducky Jan 6, 2024 08:10 PM
Maybe
Your conclusion MAY not be accurate.
The EX-L trim is a higher level than the Sport Hybrid. That being what it is, consider that the 1.5L Turbo is MUCH quieter than the 2.0L Atkinson not to mention the generator noise. I can be stopped and the engine can be revved up simply to charge the HV Batt. It appears that Honda is addressing the noise even further by using insulated glass on the front side windows in the new Sport Touring.
I do not think this is a matter of “Ya gets what ya pays for”, rather than a matter of addressing a demonstrated need.
As usual, YMMV.
theateist Jan 6, 2024 08:17 PM
Just to make sure I understand you, are you saying the Hybrid has an engine cover because the hybrid engine makes a lot more noise and the engine cover helps reduce the noise (in addition to the insulated windshield you mentioned)?
