Why wiper arm doesn't go all the way down?
sorry, what transmission has to do with it? Just to be clear, same happens while driving. And, I can hear from inside the car that the wiper goes not entirely down and I can see it visually to not go all the way down, and then it gives another push to bring the wiper all the way down as shown in the video.
This indeed only happens in "intermittent" mode. In "NON-intermittent' mode the wiper don't go all the way down too - they go to the same "almost-down" position and immediatly go up again. But in "intermittent" mode they go to the "almost-down" position and then another push to "completly-down" position. I wonder why it doesn't go all the way down in any case? It doesn't seem to be an issue with transmission, but probably design?
It appears you read it prior to deletion and your subsequent response(s) fully supported my reason for deleting my post.
However, I will attempt to explain it in much more basic terms so that you may understand the mechanics.
Modern wipers use relay modules and timers to operate the cycles. They control the interval, speed and cycle. The motor turns in one direction only. It is the transmission that delivers the motion to the wiper blades. Since the drive gear is round it must cycle fully for each revolution. The park position is achieved only at the 360* position. That is where the controller module stops the cycle and the motor is off. In intermittent mode, the motor does not advance to the off position because the timer is running. When the time interval is attained, the controller continues the cycle. Since the gear never completely finish one revolution, it must now do so in order for the transmission to reverse the travel of the arms. That is why the blades continue to park before the next revolution can begin.
So in summary, in intermittent mode the wipers are not off so they do not park.
Hope I splained it more better this time.
Jan 28, 2016 07:16 AM
