wife's Overheating CRV
Old Apr 10, 2007 | 01:01 AM
proff's Avatar
Default wife's Overheating CRV
the radiator is being checked out right now ,but i would like to know where is the thermostat and if thats it on the side of the motor closer to the firewall with alot of hoses entering it. the bolts that hold it on are very hard to get to[:@].
We both had HRV's but will never do that again due to the auto gearbox is a problem after 230,000 km and anything goes wronmg , you have to have a $7000 computer to tell you whats wrong, or search all day looking for a problem
Old Apr 11, 2007 | 01:23 AM
proff's Avatar
Default RE: wife's Overheating CRV
Well the radiator came back today from the workshop and he said he found no blockages
where is this thermostat?
Honda
Had
One
Never
Did
Again
Old Apr 11, 2007 | 11:49 AM
try going to majestichonda.com their parts catalog shows the picture of the thermostat and may help you locate it on your crv.
Old Apr 12, 2007 | 08:42 AM
On your tight bolts/nuts, apply some liquid wrench, wd40,some type of penetrant release for tight bolts/nuts and let it penetrate, put a socket or wrench on it, and tap the head or the bolt/nut-shaft with a light hammer, while turning, tapping the bolt/nut usually will come loose. Don't push so hard to break the bolt/nut-shaft.
Old Apr 13, 2007 | 02:09 AM
proff's Avatar
I DOWN LOADED ACRV SERVICE MANUAL
And found the thermostat
[:-]now i need to workout how to get those 2 bolts off.
You say they can come off with sockets???????
is this right?
one i can see from looking from the top of the motor and the other is out of sight under one of the rubber hoses,think I will have to remove that hose first.
Old Apr 15, 2007 | 08:39 AM
a socket or wrench, which ever is easier to get access to. and yes many engine parts are in a tight area and other componets may need to be removed to get to what is broken. becareful when removing the tight bolt ro nut. tap gently and apply pressure after using liquid wrench or similar lube.
proff
Jun 25, 2008 05:09 AM
infrantry
Mar 30, 2008 05:15 PM
goudge74
Aug 27, 2007 07:59 PM
dougster01
May 29, 2007 07:22 PM
Christlike
Nov 30, 2006 10:22 AM
