Cruising / Standard Valkyrie, VTX, Shadow, Nighthawk, and Rebel related information.
2005 Honda Shadow Aero vibration at speed
Old Jan 8, 2021 | 02:01 PM
Mike Schrader's Avatar
Unhappy 2005 Honda Shadow Aero vibration at speed
Obnoxious vibration begins in low 50's and increases with speed. Any ideas on how to reduce it?
Old Jan 8, 2021 | 08:19 PM
welcome to the forum. tire/wheel balance, front and rear wheel alignment. engine components. have you had anything new installed.
Old Jan 9, 2021 | 12:09 PM
[QUOTE=acmech52;36720]welcome to the forum. tire/wheel balance, front and rear wheel alignment. engine components. have you had anything new installed.
Nothing new installed by me but this is a recent purchase. Dealer said vibration is caused by an unbalanced engine on this make. I'm skeptical as vibration is bad. Are you suggesting removal of wheels to balance or alignment? Can something in the engine be the issue?
Old Jan 9, 2021 | 07:34 PM
, i am giving you options to check to find vibrations that don't cost a lot of money if a dealer says engines vibrate, i would look into why and what might be causing that. Do you get vibrations as you rev the engine up.
Old Jan 9, 2021 | 07:41 PM
No. The vibration is noticeable in high gear in the low 50's. Gets worse with additional speed. I do not rev the engine much while up shifting however.
jalindsey
Sep 22, 2020 09:31 PM
Chilleblanco36
Aug 2, 2019 05:51 PM
kdeewood
Sep 1, 2016 06:18 PM
sweetbai04
Jun 18, 2009 12:17 AM
iep
Apr 22, 2009 05:00 AM
