Cruising / Standard Valkyrie, VTX, Shadow, Nighthawk, and Rebel related information.
I'm having problems...
Old Apr 21, 2009 | 07:00 PM
sabrev45's Avatar
Default I'm having problems...
I have a 83 v45 sabre and I got it out this spring, battery was dead but charged it and it started right up, next day started right up and I took it out to wash it up, let run on idle for a few minutes and turned it off. After I was done washing and waxing I went to turn it on and nothing turned on when i turned the key. No headlight horn or even the starter. I checked the battery and it was fully charged. Any ideas of where to start looking. Is this a igniton switch problem or wiring? Let me know. Thank you -John
Old Apr 22, 2009 | 05:48 AM
welcome to the forum. check the battery terminals, besure they are clean to have a good contact. water will cause the contact to go weak. check to besure the ignition switch is dry.
Old Apr 22, 2009 | 05:28 PM
sabrev45's Avatar
Thanks, I'll take a look. I cleaned the terminals so those should be good, I was thinking that the ignition might be my next best bet.
Old Apr 23, 2009 | 02:42 AM
wd-40 all your terminals, this may displace the water and get the power back
peacemaker69
Jun 27, 2012 01:17 PM
proud-owner-of-zippy
Mar 31, 2011 07:27 AM
Unccmike49
Sep 18, 2010 09:01 AM
91haydenSI
Jan 13, 2010 01:31 PM
deftones13
Aug 28, 2009 03:18 AM
