Can't go over 2,900 RPMS or goes into neutral
I have a 2005 Honda Element with a 5-speed standard transmission. I cannot go over $2,900 RPMs or it feels like it's in neutral and goes nowhere. I have to short shift to be able to drive it right now but do not want to cause any more damage. Has anybody else experienced this issue or know what it may be
Could be but for a few dollars more you could replace unit. If you cant do that one well 2 things you could do first is check your oil level and quality, second (this one is a little more hands on) you can remove the solenoid / pressure switch unit and check the seal and screen. The screen should look clean. Hope this helps ya out
Ryan Hendricks
Jan 14, 2019 07:47 PM
