Element Forum This unique crossover provides the interior room of a minivan with the abilities of a compact SUV.
Can't go over 2,900 RPMS or goes into neutral
Old 08-29-2018, 08:25 AM
Governor36's Avatar
Default Can't go over 2,900 RPMS or goes into neutral
I have a 2005 Honda Element with a 5-speed standard transmission. I cannot go over $2,900 RPMs or it feels like it's in neutral and goes nowhere. I have to short shift to be able to drive it right now but do not want to cause any more damage. Has anybody else experienced this issue or know what it may be
Old 08-29-2018, 04:10 PM
welcome to the forum. possible vtec oil pressure switch bad.
Old 04-06-2019, 02:31 PM
Ragnar's Avatar
Default True
Could be but for a few dollars more you could replace unit. If you cant do that one well 2 things you could do first is check your oil level and quality, second (this one is a little more hands on) you can remove the solenoid / pressure switch unit and check the seal and screen. The screen should look clean. Hope this helps ya out
Old 04-06-2019, 07:40 PM
Get someone to professionally read DTC with a higher level OBD II scanner
You don't want to be replacing parts that won't fix your issue
anniqu
02-21-2020 12:36 AM
Ryan Hendricks
01-14-2019 07:47 PM
Jimmt James O
06-24-2018 01:24 AM
Daves03
12-19-2010 05:37 PM
neonstryde
12-09-2007 07:08 PM
Quick Reply: Can't go over 2,900 RPMS or goes into neutral
