2020 CRV Battery Cable Queston
Old Jul 5, 2023 | 05:51 PM
glenna's Avatar
Default 2020 CRV Battery Cable Queston
I had to disconnect the negative cable from my battery.
I pulled a bit too hard and the plastic shielding from one of the the wires (not the main cable), came out of its housing.
The wires are still properly connected.
The wires go into a housing. The shielding also went into the housing, protecting the wires (two or three thin ones, I am not in the same city as the car at the moment).
Can that be repaired?
If not, can one cable be replaced or do I need a whole set.?
Thanks
Glenn Abelson
Old Jul 5, 2023 | 10:08 PM
Picture of the actual cable would be nice.
Old Jul 10, 2023 | 07:24 AM
Sounds like housing is a connector and the wires are inside a wire loom or what you call shielding. As long as the wires are okay and no breaks, the loom can be pushed back on and up to the connector,
Old Jul 10, 2023 | 09:18 AM
glenna's Avatar
Originally Posted by avisitor
Sounds like housing is a connector and the wires are inside a wire loom or what you call shielding. As long s the wires are okay and no breaks, the loom can be pushed back on and up to the connector,
thanks will try to push it back in
Old Jul 10, 2023 | 12:22 PM
Don't sound like wire wrap. Take a picture if it.
Orangedream
Jul 11, 2023 03:39 PM
guitar548
Jun 21, 2023 03:34 PM
WheelSea
Oct 16, 2019 03:42 PM
ipecacOH
Oct 26, 2015 03:22 PM
DrDenby
Jul 11, 2015 04:46 AM
