b16a1
Old Mar 10, 2010 | 11:28 PM
tenseconds's Avatar
Default b16a1
Hey guys i was thinking do you think you can build a 10 second car with a b16a1 motor turbo and spray maybe 150 shot. Ive seen one make 600 to the wheels but don't know if its true much help would be wonderful. Thank you.
Old Mar 12, 2010 | 12:54 PM
tenseconds's Avatar
i need to find a right hand drive civic hatch back, maybe 1993. And i was seeing if maybe you guys and girls would know were to find one i know there in japan, but do you know how much it cost to import one to the springs.
Old Mar 16, 2010 | 12:13 AM
LOrangeH22hatch's Avatar
Yes its possible with th right turbo setup and some good tuning.
But a b18c might be a better choice. The added displacement will spool the larger turbo (needed to make that much power) easier.
Old Mar 20, 2010 | 07:59 PM
tiepdaihiep's Avatar
a 10 seconds car ....hahaha
ukash bingo
cash bingo
Old Mar 22, 2010 | 03:21 AM
kamalakar's Avatar
If you got your wiring done, that should plug right in. You may notice there is a technicality when using a JDM ECU. The ECU won't sit totally flat in it's mounting and the code indicator LED window does not line up with the hole in the ECU cover plate. This is because cars are right hand drive in Japan. The ECU is supposed to be on the left hand side of the car with the connectors facing right, so the way your installing the ECU is actually upside-down. Don't worry about it sitting totally flat, and drill a hole in the cover plate so you can see what code is flashing if you have a problem.
______________________________________________
Casino bonus
best casinos
