v tec wiring harness
i was lookin to buy a 1995 civic with a mini me swap in it and i was wondering if anyone has ever heard of the car not running bc there was not a vtec wiring harness. thouhg the guy said that i could pin the non vtec wiring harness to the ecu. how hard would that be to do?
RE: v tec wiring harness
a friend of mine did the mini-me swap a couple months back, and he didnt have any troubles with not starting, his v tec still is not hooked up...check into it before u buy...
yea i am thinkin he has screwed somethin up, thanks for the advice
yea man its not the vtec not wired up check your fuses but to wire the vtec its not to hard its only a cople of wires and a cople of pin connecters from radioshack there are diagrams all over the internet depending on the ecu you have!
^^^ Definitely true. Could be a siezed bearing or just a connector loose.Check the codes. A car will tell you alot about itself if you just take a few minutes and listen. It wants to run. Running is its natural place, its home. Help it go home.
Gator |
