03 Accord HVAC/Radio lights not coming on?
Hi there. New to the forum. My issue is that the backlights for the HVAC/RADIO controls are not working.I've seen that this is a common problem for this year of Honda's, been using the search tool here as well as google and i'm looking at doing a blown fuse removal on the board of the radio in order to get the backlights on the radio/HVAC controls working. Pretty good tutorials online im ready to do it i just have one question before i do it.
The actual backlight of the radio works fine, i can see the time and it lights up great. The issue is that all of the controls for the HVAC/RADIO do not light up. Im just wondering if it still can be that fuse if the radio backlight is working and not just be that all of the bulbs are burnt out. Nobody seems to specify so i'm just wanting to make sure before i go monkeying around with the board
Thanks for any help and i look forward to digging around this forum for any more problems i have
I have the Honda Factory Service Bulletin with Parts Information.. They had a circuit board that was commonly replaced to correct this issue under warranty. I believe I still have a couple of the circuit boards in stock
Pm me and Ill send it to you
hope this helps
hope this helps
JennyBoo311
Mar 4, 2021 07:06 PM
cookiekare
Sep 23, 2019 11:27 PM
Rich0591
Sep 9, 2009 03:33 AM
