07 Accord AC Prob. Blend door? Control issue?
Rookie Forum user. Hope I am doing this right.
My AC will only work if the temp dial is one click off max cold.
This is a Manual Climate control vehicle.
When asking for heat, if you turn the **** to full heat, it is warm.
The radio is the 6 disc changer model.
Someone mentioned that the block on the radio could be defective.
I'm at a loss.
It is almost as if, the minute you turn the dial off the one notch for full cold, the blend door switches to heat. Compressor keeps running, it just cannot compete against the heat exchanger wide open.
Tnx, Doug
I'm at a loss.
Tnx, Doug
m.e.greene
08-24-2019 02:36 PM
