07 Accord AC Prob. Blend door? Control issue?
Old May 11, 2015 | 06:55 PM
douglauraholtz's Avatar
Default 07 Accord AC Prob. Blend door? Control issue?
Rookie Forum user. Hope I am doing this right.
My AC will only work if the temp dial is one click off max cold.
This is a Manual Climate control vehicle.
When asking for heat, if you turn the **** to full heat, it is warm.
The radio is the 6 disc changer model.
Someone mentioned that the block on the radio could be defective.
I'm at a loss.
It is almost as if, the minute you turn the dial off the one notch for full cold, the blend door switches to heat. Compressor keeps running, it just cannot compete against the heat exchanger wide open.
Tnx, Doug
Attached Thumbnails 07 Accord AC Prob.  Blend door?  Control issue?-07-accord-radio.jpg
m.e.greene
Aug 24, 2019 01:36 PM
zedjr
Sep 21, 2012 01:38 PM
Utilityman54
Nov 7, 2009 02:46 AM
slow1500
Mar 19, 2009 08:04 PM
frenoloco
Feb 25, 2009 10:39 PM
