1992 Accord EX Turns Over Then Dies Will Not Run 2.2L 140hp
1992 Accord will not run. I have tested the distributor and coil but both work fine. I have also replaced the main relay but it will still not run.
I am fairly sure the fuel pump is working since there is pressure when I remove the line going into the manifold.
The timing belt appears to not have slipped either.
Any suggestions?
Any suggestions?
snowmangaggift
Aug 8, 2013 05:09 AM
jordtee
Sep 18, 2008 04:57 AM
