1992 Accord EX Turns Over Then Dies Will Not Run 2.2L 140hp
Old Oct 4, 2011 | 08:05 PM
keegross's Avatar
Default 1992 Accord EX Turns Over Then Dies Will Not Run 2.2L 140hp
1992 Accord will not run. I have tested the distributor and coil but both work fine. I have also replaced the main relay but it will still not run.
I am fairly sure the fuel pump is working since there is pressure when I remove the line going into the manifold.
The timing belt appears to not have slipped either.
Any suggestions?
Old Oct 5, 2011 | 01:22 PM
rkenyon4106's Avatar
You say it runs then dies immediately? Have the alternator tested. The fuel pump runs on battery power during start up but switches to alternator power during run.
snowmangaggift
Aug 8, 2013 05:09 AM
ddland0917
May 22, 2010 05:11 PM
jordtee
Sep 18, 2008 04:57 AM
jimbojam
Dec 9, 2007 05:35 PM
tdankow
Sep 13, 2006 04:54 PM
