1993 Honda civic DX HB
Old Jul 16, 2009 | 03:28 PM
Grimbledj's Avatar
Question 1993 Honda civic DX HB
It grinds when I shift into 2nd. Do you think this is something I can fix or should I swap out the tranny. all stock motor and tranny
Old Jul 17, 2009 | 03:41 AM
when was the last time you changed your trans fluid with Honda fluid?
Old Jul 17, 2009 | 01:05 PM
Grimbledj's Avatar
I just bought the car not sure that is something I can try. Thank you. Some guy off C/L said it needs a new tranny but I dont think it does.
Old Jul 20, 2009 | 12:18 PM
Grimbledj's Avatar
I replaced the clutch and pressure plate and put honda MTF it runs 90% better but still grinds into 2nd at high RPMs. I think rebuilding the tranny will do it...Thanks
Old Jul 21, 2009 | 08:11 PM
92DAkaos's Avatar
the grinding issue usually has to do with the syncros in the trans but ive never heard of 2nd gear its usually the 3rd gear grind but most honda trans start having that problem around 170 to 200000 milesthe best option is a rebuild
ias11
Sep 1, 2008 10:29 AM
bristow
Jul 24, 2007 06:49 PM
pugads650
Mar 20, 2007 08:51 PM
projectv8killer
Nov 25, 2006 06:59 PM
projectv8killer
Sep 18, 2006 05:52 AM
