1994 ACCORD EX NO Fuel pump BUZZZZZ
Changed the pump still no BUZZ and also changed the Relay still no BUZZ. Fuel Pump Fuse still good. Accord would not start lots of miles on car but still runs good. Started changing parts re soldered the Fuel Pump Relay then Changed the Relay next I changed the Fuel Pump. WHERE DO I GO NEXT???
Replaced both the Fuel Pump Relay and Fuel Pump no help. But you turn it on and off several times and buuzzzzzzzzz it works. You let it sit all night long and try to crank it up in the morning and it starts. You let it sit all day long when it's warm and no freaking buzzzz. Tried 2 different Relays no difference. Only fix for now is to move to Alaska where it's cool year round. Maybe the start switch?? it acts normal when you operate it. Not sure where to go from here it has Gremlins or maybe an Exorcisem could work.
lp284
Nov 8, 2010 12:36 AM
