1994 honda accord ex transmission problem
Old Dec 16, 2011 | 09:12 AM
Donkeydawn11's Avatar
Default 1994 honda accord ex transmission problem
Hi everyone I need some help I have a 1994 honda accord ex auto
I replaced the engine a couple of weeks ago and have noticed my rpms have been getting high they are sometimes up to about 2k well the other day I was driving on hwy I had to accelerate alot to get the car to move forward coming off the hwy the vehicle would go forward in any gear
after giving it a lot of acceleration I finally got it home while it was parked I tried to shift in the different gears and none of them would engage.
I have noticed that the rpms are very high at about 2k
Does anyone know what this might be or does it mean that the trans need to be replaced.
Old Dec 16, 2011 | 12:46 PM
Sounds like the trans is slipping.
Old Dec 27, 2011 | 09:25 AM
eddiecarrara's Avatar
The first thing I would check is the transmission fluid level. It's very common for a transmission to slip if the transmission fluid is hot and low. You need to check the trans fluid when it hot and the engine is off, sitting on level ground. If the trans fluid is to high, it will also cause some funky shifting problems. You can check out an article I wrote about #1 Reason for a slipping transmission for more details, I think the videos will help as well http://eddiecarrara.hubpages.com/hub...g-transmission
Old Dec 27, 2011 | 09:45 AM
Very nice Eddie!
cody11ca
Feb 1, 2024 08:59 AM
Donkeydawn11
Mar 13, 2012 11:11 AM
Donkeydawn11
Feb 9, 2012 10:37 PM
Donkeydawn11
Jul 2, 2010 10:01 PM
Donkeydawn11
Sep 10, 2009 02:26 AM
