1997 CRV oil level
Old Aug 23, 2015 | 01:38 PM
anon125's Avatar
Default 1997 CRV oil level
the dealer changes the oil.
the dipstick has 2 holes. the top one is supposed to be the max.
whenever we check it, the oils is always over that amount.
we check in the morning before use.
are they putting in too much oil?
thanks
Old Aug 26, 2015 | 02:37 AM
no, when honda does your oil change, they put in enough oil to compensate for the oil filter, run the engine and then recheck the oil level. If you run your engine first, then check your oil, it should be at the top hole.
Old Aug 26, 2015 | 09:52 AM
anon125's Avatar
Thanks, so weeks later if we check it in the morning where should the level be?
Old Aug 27, 2015 | 03:06 AM
after a short run and providing the engine is not burning oil, it should be at the top hole. (Just for info, My o7 Fit from the time I purchased it, at 60% oil life, i add a quart, at 30% oil life I add a quart of oil. currently it has 250k miles and runs good.)
Old Aug 27, 2015 | 11:23 AM
anon125's Avatar
we have never added oil to our 97 Honda in 17 years. it is low mileage.
the oil is always beyond the top hole.
thanks
Old Sep 8, 2015 | 09:58 PM
lowlife9's Avatar
thanks
jesus you never changed the oil in 17 years ???
Old Sep 9, 2015 | 12:31 PM
anon125's Avatar
correct.
what I wrote was I never added oil.
the dealer did the oil changes
anon125
Oct 17, 2015 12:09 PM
leep
Jun 11, 2013 10:02 AM
Frodo_DLB
Oct 6, 2009 02:29 PM
shad9876
Sep 3, 2008 12:57 PM
