1999 Honda motor swap to a JDM
Old 08-25-2016 | 09:53 PM
mc804's Avatar
Default 1999 Honda motor swap to a JDM
Hi all. I am at the good end of a motor swap. (I hope) I bought a JDM Honda with the knock sensor. I'm hoping it's the hi compression one. I was told it was when I purchased it.
My issue now is that my wiring harness, as it seams there is more receptacles for the wire harness than the JDM engine has. Also is there a trick to laying that thing out so its memory" wil kinda show ya where it goes.
I have found out the hard way that the A/C compressor bracket and power steering pump are different, so I'm using the originals. Any help would be awesome.
Old 08-25-2016 | 10:09 PM
mc804's Avatar
Default Yes and no
I'm in the middle of my swap. Here's what I've found out with mine...
1. The distributor that came on the JDM has a different plug on it than the original.
2. The power steering pulley is bigger on the JDM engine, so the belt don't work. I had to use my original.
3. I'm stumped with the wiring harness currently, it seams that there are more places on the original motor (B20Z)
4. I had to change the oil pump on the JDM motor as it didn't have a CPS on it.
Hope this helps.
shreve66
08-25-2016 10:11 PM
livinlif3
07-27-2010 05:23 PM
toytruck89
05-06-2007 02:30 AM
streetburner
12-25-2006 05:43 PM
bobby
03-22-2006 04:28 PM
