2000 civic lx died while driving
Old Apr 26, 2008 | 11:31 PM
nighthawk5556's Avatar
Default 2000 civic lx died while driving
We've had this Civic for maybe 4 years now (bought it used). It's always been a really good car. It's always taken maybe a second or two to crank....figure maybe thats just cuz we park it somewhat uphill.
The other day my wife called me and said it just stopped running and left her stranded. No check engine warning or anything prior. Towed it home (redneck style with a tow-rope) and disconnected line exiting fuel filter and turned it over and it put out a good bit of gas constantly. Starter turns motor over really well (good batt and alt). Tried several redneck ways to check for spark and couldn't get anything. Had a friend of a friend (who used to work for Honda as a mech.) check some stuff and he said the coil checked out good, but didn't like the readings from the ICM(Ignition Control Module). Bought one, put it on........still nothing. I was also told to see if timing belt broke, but it was still intact and looked really good.
I'm an idiot when it comes to automotive electronics by the way, but have a good multimeter. I'm just lost on what and how to check. Any help at all would be greatly appreciated. Thanks.[/align]
Old Apr 27, 2008 | 01:14 PM
Default RE: 2000 civic lx died while driving
Welcome to the fourm nighthawk5556: If you have high milage 90-112k the timing belt may have jumped a tooth stripped a tooth to jump timing, this is about the time for belt change, If you have a service manual, you can turn the engine to match the crank and cam dots to see if the timing is correct. besure you are on the compression stroke.
kevin_405
Jun 18, 2012 07:09 AM
sadbuttrue08
May 24, 2009 08:49 PM
juschilin77
Apr 28, 2009 03:18 PM
Sharjite
May 25, 2008 03:52 PM
largoent
Apr 11, 2007 11:53 AM
