2000 Honda Accord V6 Misfire
Old Feb 13, 2016 | 06:35 PM
Chris Martin's Avatar
Default 2000 Honda Accord V6 Misfire
Hello,
I'm having problems with my cylinders misfiring. The check engine light can on and I checked it and said #4 and #5 cylinder misfire. I changed the spark plugs and coil packs and it started doing it again. The check engine light came on again and it said #2,#4,and#5 cylinder misfire now. What is the problem and how can I fix. It only has 157k original miles.
Old Feb 17, 2016 | 07:28 AM
welcome to the forum. check your valve adjustment. this sometimes causes the misfire indication.
Old Jul 25, 2022 | 01:28 PM
bam32569's Avatar
You can also do a compression test and compare the readings
Old Jul 25, 2022 | 06:21 PM
Since it's been 6 years I doubt they are still concerned with it.
Old Jul 26, 2022 | 05:43 PM
bam32569's Avatar
New to this, didn't check the date but still good advice.
cutlas
Jan 23, 2016 06:08 AM
Forrest
Nov 30, 2012 08:48 AM
Tommy504
Nov 5, 2009 08:24 AM
brikcity
Jan 9, 2009 04:32 AM
billybop45
Mar 19, 2008 03:01 AM
