2001 Accord P1147 Error Code?
Old Oct 8, 2009 | 10:07 AM
C Check's Avatar
Default 2001 Accord P1147 Error Code?
What is this code? I replaced both O2 sensors and this is the code it gives? I reset it and it stays off for awhile but comes back on after 60 miles or so.
Old Oct 9, 2009 | 06:17 AM
welcome to the forum. ( code 1147 shows ETS sub Accel Position 1 malfunction for a Hundai. Unable to locate this for a Honda accord.) 1149 honda code is Primary HO2s Sensor 1 Circuit Range/Performance Problem. light comes on may be due to something else beside the o2 sensor causing it.
Old Oct 9, 2009 | 09:49 AM
C Check's Avatar
I know thats why I'm confused. I originally had the 1149 code so I replaced both sensors and that code went away but then code 1147 came on after driving. It says air/fuel ratio sensor 1, heated oxygen something on the scanner.
jacony
Feb 17, 2015 01:54 PM
elduderino
May 10, 2013 09:00 AM
robber6910
Aug 10, 2010 11:53 AM
tampa1
Apr 28, 2010 02:13 AM
plcboy
Mar 13, 2007 01:26 AM
