2002 4 cyl v-tec low power
Old Aug 26, 2012 | 01:40 AM
studebaker's Avatar
Default 2002 4 cyl v-tec low power
Car will down shift at the smallest of hills. Seems to have low power. Gas millage is 21 -23 MPG. This is my fourth Honda and I expected around 30. I have put 100,000 miles on this car in 2 years. Ck engine off till 2 weeks ago. Code says misses on number 2 and 4 cylinders and random misses and v-tec issues. From a stop you can floor the gas pedal and it will make it to 6000 rpm and shift to second. 5 to 6000 goes slow. In second it falls on its face in that it only goes to 5000 and floats around to 5200 but will not shift up till you let up on the gas pedal. I put in new plugs, wires, cap , and rotor. Results no difference. What next??
Thanks for any help
Old Aug 26, 2012 | 08:48 PM
lowlife9's Avatar
how did you install wires,cap,rotor on a car that doesn't use any of those???. your car uses coil packs maybe those need replacements. as for the vtec remove the vtec solenoid and clean it as seen here http://www.civicforums.com/forums/11...e-up-mods.html please read this before you go getting your halogen lights refilled. http://www.aa1car.com/library/misfire.htm
wayne0
Jul 19, 2012 07:32 PM
tomwegeng2000
Oct 14, 2009 02:51 AM
keglerking
Oct 28, 2008 09:38 AM
nelpasa
Mar 9, 2007 11:02 PM
lunch_box
Apr 25, 2006 12:06 PM
