2003 CRV idle speed
Old Aug 30, 2006 | 04:34 PM
jmurphnd's Avatar
Default 2003 CRV idle speed
2003 CRV. When I start her up after she's been sitting around for a few hours the idle speed in Park runs around 1,800 rpm. Gradually comes down as the engine warms up. no check engine, or warning lights come on HELP!
Old Aug 31, 2006 | 11:52 PM
golfer's Avatar
Default RE: 2003 CRV idle speed
is this something new?
if so what was it before ?
Old Sep 1, 2006 | 07:32 AM
jmurphnd's Avatar
Past week or so. Didn't pay that close attention to it, but I believe it used to be around 700-800 rpm. seems to be worse when starting up on cooler mornings. Thanks for replying.
Old Sep 1, 2006 | 10:05 AM
golfer's Avatar
Ifitstarts at 800 rpm when cold, that would be a problem.
At cold start the engine will rev about 1200 rpm then as the engine warms the rpms will come down to about 700 - 800 rpm and level off.
This would probably take afew momentsor so to doand as the air gets colder it will take longer.
If it stays high rpm andwon't decrease until the temp. gauge moves possibly the intake air temp. sensor may be faulty.
Old Nov 30, 2006 | 10:31 AM
Benniehonda's Avatar
Yeah it's normal it's called cold start fast idle.Don't worry about it.If there was a problem with the idle control system a check Mil would be present.
the spec after engine is warm is 650RPM plus or minus 50
stephshonda
Aug 11, 2015 04:32 PM
julzietron
Jul 23, 2015 02:50 AM
biker19
May 20, 2013 12:15 PM
jmurphnd
Sep 20, 2007 10:09 PM
ssameer2601
Nov 5, 2006 04:28 PM
