2005 CRV Troubles
Recently transplanted a Motor and Transmission from a 2006 CRV into my 2005. Have it up and running but seem to have trouble "finding"reverse gear with shifter. Can sometimes get reverse from under the car by wiggling the input shaft into tranny by hand. HELP PLEASE!
I used Honda tranny fluid when I filled it. Also I was told that this model had no filter by the local dealer.
Does the instrument cluster say you're in reverse when you have the problem?
The transmission is electronically controlled, so if the computer doesn't tell you you're in reverse, you might want to check the Range Position Sensor, and see if it's adjusted right or defective.
If the gauges say you're in reverse, and you get no engagement, you might be having trouble with the shift solenoids, or the transmission might have mechanical problems.
on a 4 wheel disk brake, should not unless there is by pass in the master cylinder. on a rear drum you may feel a small pedal bump due to the fwd brake liner comes more into contact with the drum to keep the vehicle stopped in reverse.
