2010 Brake problem
Old Jun 19, 2018 | 05:05 PM
msnden's Avatar
Default 2010 Brake problem
Hi Just purchased a 2010 Honda CRV with 120K, runs great, however my brake lights quit working, no problem put in new ones, didn't help, looked for a fuse but could not find one for the brake lights. would anyone have any idea as what to check, I am not a very good mech. but I can do a few things, Thanks
Old Jun 20, 2018 | 01:31 AM
welcome to the forum. there may be a switch on the brake pedal shaft area. need to craw under steering column and look up.
Old Jul 3, 2018 | 12:44 AM
Hondatech92's Avatar
Try checking your Fuse 12 Under/hood 15amp before checking the brake switch
Old Jul 22, 2018 | 03:57 AM
Rennmeister's Avatar
If you have a multimeter, you can also check for voltage at the fuse (top of the fuse generally has a probe spot) and also at the taillight plug(s). If both are out, I'd suspect a switch in the system. Start at the pedal box and go from there.
Old Jul 22, 2018 | 08:03 PM
Most likely the switch at the pedal.
Jesse Tiznado
Dec 1, 2017 08:59 PM
Barletter
Jul 3, 2014 12:47 PM
Ltt
Jun 10, 2009 03:39 AM
pluck22
Dec 15, 2008 10:44 AM
93jdmcfcivic
Jan 5, 2006 03:39 PM
