2011 civic 1.8 sputters
Old Sep 13, 2020 | 01:02 PM
Gino Savoie's Avatar
Default 2011 civic 1.8 sputters
hey guys! Little issue here . I have a 11 honda civic dx-g and everything seems to be working fine except when the car is in neutral or with clutch engaged , if I pump the gas pedal a few times to take off it seems to "cut out , sputter when I let go of the gas " like as if there was extra compression or no air or gas is being sent to the engine. And no there is no codes , any ideas?
Old Sep 13, 2020 | 05:42 PM
welcome to the forum. check to see if your idle cut off is clean. also clean your throttle body.
Old Sep 16, 2020 | 12:16 PM
Thankyou ! And I have cleaned out my throttle body . But I'm not familiar with the idle cut off . Where is it located ?
Old Sep 16, 2020 | 08:28 PM
it should be along side of your throttle body. if you google idle control valve it will show you how to clean it also,.
NCjohn
May 31, 2019 09:51 PM
Ray Albert
Sep 19, 2018 07:27 PM
madabouthonda1
Nov 25, 2015 08:47 PM
Jlj21usmc
Jul 30, 2014 05:05 AM
Tclay1957
Dec 13, 2013 06:55 AM
