2013 Accord - Occasional Flashing Check Engine Light
Old Aug 14, 2022 | 12:01 AM
smoothc's Avatar
Default 2013 Accord - Occasional Flashing Check Engine Light
Hi,
I've recently notice my Honda struggling to accelerate ~2 RPM. Whether just gaining speed to merge onto a bigger street or up a slope, the car will occasionally jerk/stutter before picking up speed. Once this started to happen, I've been more cautious in accelerating. Recently the malfunction/check engine light flashed on while I was driving and I lost the ability to accelerate - the gas pedal didn't have an effect when this light flashed, I was basically coasting at speed.
I read the manual, let the car cool down and was able to drive it safely back home. Next day, I took it into the shop, the mechanic said there were no stored codes, the car is fine and just drive it normally. I was pretty skeptical but he insisted and I just moved on. The issues came again recently and the check engine light flashed again about a week later (today).
I'm planning to take my car back into a new shop, but I want to go in with some expectation and knowledge about what this issue could potentially be. Is this a common issue? What can I expect when going into a shop so they don't take advantage of the situation? I did some reading and my guess on this issue is something with the transmission / transmission fluid.
Old Aug 14, 2022 | 12:18 PM
You had a flashing CEL and there were no stored codes? Was the battery disconnected?
A transmission is not going to flash the CEL. That only happens for engine misfires. How long has it been for plugs and such?
Old Aug 14, 2022 | 12:20 PM
Also it's good to supply us with basic information
Year
Make
Auto/stick
mileage
Old Aug 14, 2022 | 05:58 PM
smoothc's Avatar
Hmm so I'm pretty dense about car specifics outside of general maintenance. By plugs, do you mean the spark plugs? I don't think those were ever changed in the last 5 years. The battery has not been disconnected.
That's correct in that I had a flashing CEL and no stored codes. The flashing CEL was a somewhat "random" occurrence. It happened once on the freeway, I managed to get out and let the car rest. Started it back up, no CEL for over 2 weeks. It just recently flashed again, for less than 3 minutes. It doesn't come on every time the car starts, but I do notice my car struggling to accelerate up to normal speed limits. The first mechanic just gave me a free diagnosis by plugging in the device to check for stored codes and said the car is fine. I'm going for a second opinion at a different place, but I just want to be somewhat informed before walking in.
Here are the car specs:
2013 Honda Accord LX (the lowest base model)
Auto
80k mileage
What may provide some insight: this car did not have the best history of receiving regular oil changes. The last year of oil changes were good and have been at 5k / 5-6 months. But the years prior to that were not in the best routine (to the point where one oil change was very black and sludge-ish).
Old Aug 14, 2022 | 10:41 PM
You need to put a set of plugs in. That ,may cure your flashing light.
Old Aug 21, 2022 | 05:11 PM
smoothc's Avatar
hey! Thanks for the responses and solution - it did end up being the spark plugs. Car feels waaay better now. I never knew when to replace plugs, gotta put down a reminder for myself.
Old Aug 21, 2022 | 09:42 PM
They should be good for 100K.
Sam Abrams
Oct 24, 2015 06:44 PM
Ostravaczech
Jun 3, 2013 10:16 AM
rad384
Aug 17, 2012 10:32 PM
spike817
Sep 4, 2009 02:51 PM
daperfectmix
Jan 29, 2009 12:26 AM
