2013 CRZ Stuck Parking Break -- Help!
Old Mar 22, 2014 | 03:17 PM
hackingwood's Avatar
Unhappy 2013 CRZ Stuck Parking Break -- Help!
I have a very lightly used 2013 Honda CRZ. I drive it pretty regularly and use the parking brake almost every time I park. After getting in my car and lowering the parking brake, I noticed the car wouldn't move. When I pull up on it, there is NO resistance from the lever until the second click, and then it exerts the normal amount of resistance. It feels like it's locked on. I can put the lever all the way down, and the parking brake light turns off, but the brake remains on, regardless of the lever's position.
I have tried going up and down a bunch with the lever in hopes of loosening it, I have tried rocking the car back and forth, shaking it, climbing underneath to see if anything looks awry, and even taking the plastic casing around the e-brake off. I am at a loss, and very frustrated. Please help!
Old Mar 23, 2014 | 05:16 PM
Try going under the car and tugging on the brake cable it maybe stuck,I have had this happen on my truck,if this is the case then lube every connection you can under the car with lithium spray
flybee
May 17, 2015 06:58 AM
Marc
Feb 25, 2013 11:25 AM
swenrac
Jun 8, 2010 07:53 AM
antbegone
May 10, 2008 03:26 PM
