2014 Honda CRV with code p0341
Old May 8, 2025 | 04:07 PM
MrTracker's Avatar
Default 2014 Honda CRV with code p0341
hi, I have a 2014 Honda CRV with code p0341. Have some troubleshooting planned but thought I would check here first before spending my cash on those.Common Causes of P0341 Code
#1 Faulty Camshaft Position Sensor: The sensor itself may be damaged or malfunctioning. - replace the sensors
#2 Timing Chain or Belt Issues: If the timing chain has stretched or skipped a tooth, it can cause misalignment. - view the timing chain for stretching.
NOTE from AI: P0341 points to the intake camshaft position sensor circuit. The sensor itself is a prime suspect and a common fix, but don't rule out wiring or, less commonly, a mechanical timing issue.
Any others I should get the tech to check on Monday? thanks!
goco
May 8, 2025 08:23 PM
wwdwgs
Jul 21, 2024 06:39 PM
HondaDude48
Nov 22, 2021 08:44 AM
JMBB
Mar 11, 2021 08:47 PM
