2016 Pilot AWD differtinal fluid fill
Just drained and refilled my diff and I put in 2 quarts and ~8 oz. Manual says it should be 1.9ish quarts. Can you overfill? I filled to about 1.8, started the engine, put in dirve for 10 set and spun the tires, then stopped wheels and put in reverse and spun the wheels ~ 10 seconds, then back in drive for 10 sec., finally put in park and continue to run engine for ~20 sec. NO spill or overflow. Topped up fluid until it just started to flow out the fill whole,,, wiped everything up and reinstalled the fill plug.
Ken |
welcome to the forum. as long as you filled it as per manual you should be good to go. also using proper fluid per manual. keep up the good work.
