89 Accord trouble
Old Jun 17, 2010 | 05:41 PM
mikeds49's Avatar
Question 89 Accord trouble
I have a 1989 Accord LXI that was running great, then the solenoid went bad..I replaced the starter..when I turned the key on the tachometer pegged and it turned over like it was 70 to 90 degrees advanced..unplugging the spark plugs & it turns over fine..centrifigal advance, vacuum advance & vacuum retard are working fine..I replaced the coil & ignitor but they did nothing..I even got another new starter but that did NOTHING...could this be distributor trouble...the car has 291K but like I said it was running great...any help would be greatly appreciated
Old Jun 18, 2010 | 02:37 AM
check your timing belt, it may have slipped a tooth. when did you last change it.
Old Jun 18, 2010 | 05:48 AM
mikeds49's Avatar
Default 89 Accord trouble
will check the timing belt ASAP...thank you..havent changed t-belt since purchase in April
Old Jun 18, 2010 | 04:53 PM
mikeds49's Avatar
Default 89 Accord trouble...still
timing is ok...any more thoughts???
sherrib1027
Jul 30, 2011 08:17 AM
starrett59
Sep 17, 2010 01:20 PM
captmoto
Sep 4, 2010 10:45 AM
chuck norris hx
Nov 30, 2006 10:24 AM
bigmark
Apr 28, 2006 03:08 AM
