92 accord options ?
Old Jul 11, 2016 | 10:21 PM
MT93's Avatar
Default 92 accord options ?
Hello, new here
I was given a broke down 92 accord ex 4dr f20a auto trans.
Got it running finally after new main relay and cap&rotor & battery, only to realise the trans is on its last leg. Shifts into 2nd HARD. The local junkyard has a few options, could slap an identical trans in it, or there is a complete 88 accord f22a with 5spd,harness,ecu... Unknown mileage on both though.
Is a conversion to manual trans possible with parts on the 88?
Would LOVE to get to some more power & fun out of this car.
There's also an early 80s(I think) integra with a k20, what motor mounts would be needed for the swap?
I've been seeing a lot of posts around the web on a H22a swap being direct bolt in, is there a source to order a complete swap kit? Eng/trans mated with harness & ecu?
Ever since I owned a Crx with b18 I've been dieing to build something with comparable speed/acceleration
If you had this car & about 1k to spend what would you do?
Old Jul 12, 2016 | 07:14 PM
Welcome in,I would simply change out the trans,opting for a manual would be difficult to install a clutch assembly.good luck.
Old Jul 13, 2016 | 05:54 AM
welcome to the forum. I would stick with an auto.
Old Jul 13, 2016 | 12:23 PM
MT93's Avatar
I have been reading a lot of posts saying the trans from an f22a4 has more aggressive gear ratio, can anybody confirm this or lead me to some sort of chart/guide?
Hard to make a decision when a lot of what is posted is contridicting , and I can't seem to find any actual info on this besides what's posted on a few forums
Thanks in advance
jad
Mar 28, 2015 06:55 AM
mark53
Jan 25, 2015 08:16 AM
TheKraken
Jan 23, 2015 11:47 AM
S-LudeDan
Nov 11, 2009 02:04 PM
Palindrake
Mar 4, 2008 11:32 AM
