93 Accord Intermittent Run Problem
Old 05-23-2007 | 11:32 PM
turkeytrot's Avatar
Default 93 Accord Intermittent Run Problem
I'm having an intermittent run problem with my 93 Accord that has stranded my daughter several times. The car just quits as she is driving down the road. It will turn over but not recrank when this occurs. The fuel pump is working when this happens. After letting the car sit for a while it will recrank. Ignition module or other ideas to check? Thanks.
Old 05-24-2007 | 02:00 PM
Default RE: 93 Accord Intermittent Run Problem
possible fuel filter if not changed, distributor cap or rotor, ignition module,worn plugs, main relay going bad/dirty, or ecu.
keegross
10-05-2011 02:22 PM
mmgehrig
09-01-2010 06:22 AM
knt2010
03-19-2010 04:16 AM
jgelis
01-31-2010 03:13 PM
rpankau
01-06-2007 04:57 PM
