93 Accord Intermittent Run Problem
Old May 23, 2007 | 10:32 PM
turkeytrot's Avatar
Default 93 Accord Intermittent Run Problem
I'm having an intermittent run problem with my 93 Accord that has stranded my daughter several times. The car just quits as she is driving down the road. It will turn over but not recrank when this occurs. The fuel pump is working when this happens. After letting the car sit for a while it will recrank. Ignition module or other ideas to check? Thanks.
Old May 24, 2007 | 01:00 PM
Default RE: 93 Accord Intermittent Run Problem
possible fuel filter if not changed, distributor cap or rotor, ignition module,worn plugs, main relay going bad/dirty, or ecu.
keegross
Oct 5, 2011 01:22 PM
mmgehrig
Sep 1, 2010 05:22 AM
knt2010
Mar 19, 2010 03:16 AM
jgelis
Jan 31, 2010 02:13 PM
rpankau
Jan 6, 2007 03:57 PM
