93 accord overheating
Old Mar 29, 2008 | 10:17 AM
infrantry's Avatar
Default 93 accord overheating
i have a 93 accord which is over heating. I replace the waterpump, timing belt, radiator and thermostat and its still overheating. I took off the thermastat and now it does not over heat. Now when the car heats up it smell like antifreeze inside of the car but i checked everywhere and there are not leaks. Any suggestions on what it might be or why it over heats with the thermastat on
Old Mar 30, 2008 | 05:15 PM
Default RE: 93 accord overheating
Possible overheat,the rad fan does not kick in when the rad temp gets up to 210, smell of antifreeze may be coming from engine compartment past the center hood area ( the seal may be worn) and entering the inlet area outside, middle area of the windshield. Or there may be a open hole from the engine compt into the cab. When the car is at idle, and the temp goes up approx 3/4, does the fan go on. Also if the a/c is turned on, the fan also goes on.
Ms_Hannah
Oct 10, 2010 11:35 PM
illn0tsick
Apr 5, 2010 12:46 AM
greenleg88
Mar 4, 2009 10:50 PM
goudge74
Aug 27, 2007 07:59 PM
dougster01
May 29, 2007 07:22 PM
