94 Civic tie rod issue
Old 06-23-2009 | 05:14 AM
wayne0's Avatar
Member
Default 94 Civic tie rod issue
I recently bought a stock 94 Civic del Sol. The tie rod ends were replaced but it was never aligned.
I took it to an alignment shop and was told the left inner and outer tie rod ends were maxed out. It's eating my tires. (too much toe-in)
How do I fix it? Is there a longer tierod available?
Thanks in advance.
Old 06-23-2009 | 01:43 PM
welcome to the forum. Check your tie rod ends for part nbrs if possible. Go to hondaautomotiveparts.com and compare part numbers if possible or go to autozone.com and see if there might be a listing of tie rod part numbers. If no part number, you can call any parts house and take your tie rod off and compare the length. Possible wrong type put in.
Old 06-23-2009 | 04:14 PM
wayne0's Avatar
Member
Thanks. I'll check that out.
Old 06-24-2009 | 06:21 PM
wayne0's Avatar
Member
Problem solved. Had to pull the outer tie rod end and chase the threads. Gained another 1/2 inch! The tie rod would bind up giving the illusion of bottoming out.
Old 07-11-2009 | 11:58 AM
Good find, your experience now has assisted others to trouble shoot and fix their problem.
lookOut
04-29-2015 04:02 AM
proud-owner-of-zippy
03-01-2011 10:00 PM
Mag Auto Parts
11-13-2008 01:27 PM
nathancrowder
10-10-2008 02:59 AM
89crxdx
11-01-2007 05:12 AM
