Ac not work
Old Jun 14, 2010 | 09:15 PM
Hotrodinvi's Avatar
Default Ac not work
hi Another issue with this 2002 crv. The ac just stop working I checked fuses relays under the hood and in the fuse box everything looks good checked the compressor it looks ok check the blower with a 12 volt source and it came on. Could it be the ac switch or is there some other relay that is in the car like the main relay. Does any one have an idea what the problem may be. Thanks
Old Jun 15, 2010 | 01:20 AM
a/c pressure switch is bad or check to see if you have pressure in your system first.
Old Jun 15, 2010 | 05:22 AM
Hotrodinvi's Avatar
Thanks I checked the system and it has pressure. If the pressure switch is bad would it cause nothing to work? When I turn on the system not even the blower comes on.
Old Jun 16, 2010 | 03:00 AM
If the pressure switch is bad, the cool part does not work, the blower is the fan switch or blower itself may be bad. put some voltage to the blower and see if it turns
Old Jun 17, 2010 | 10:08 AM
Hotrodinvi's Avatar
Thank you I found out the problem it was a ac resistor in the blower box. If that fails the system would shut down and nothing would work. Thanks again for your help
Old Jun 18, 2010 | 02:28 AM
good find, thanks for coming back to update. good follow-up
dsrobin
Oct 27, 2014 08:32 AM
dsrobin
Oct 27, 2014 07:18 AM
PaulPool89
May 23, 2014 10:57 PM
masduud
Jun 23, 2010 11:37 AM
sherick_s
Sep 2, 2009 05:10 AM
