AC problem - Need PAG oil?
Old Jun 10, 2022 | 11:36 PM
LightninHopkins's Avatar
Default AC problem - Need PAG oil?
My AC stopped working.
I ordered a A/C Refrigerant Hose / Line on high side because there was a small, small leak, and I want to change the receiver drier before I order a brand new Denso compressor. Hoping that it will work again.
My question is that do I need to buy PAG oil to lubricate o-rings on these parts? Denso compressor will come with oil in it (if it comes to that) so I am wondering if I must buy it. Or can I use engine oil? Or nothing?
Also for 2002 Accord, do I need to remove the bumper to get to receiver drier? I see it, but I don't know if I can get to it.
Old Jun 11, 2022 | 11:30 AM
Use pag or olive oil.
Old Jun 11, 2022 | 09:16 PM
Olive oil!?
I was looking at walmart website. Can I use bulb grease instead? Regular dielectrical grease is expensive, but this one is like $3, and it says dielectrical. So I don't know the difference. Maybe only the packaging and marketing.
Old Jun 11, 2022 | 10:26 PM
You are not looking for a good electrical connection you are looking for the proper lube.
Old Jun 11, 2022 | 11:30 PM
Youtube has a video that shows how to replace Civic high side line, and when it was taken off, pag oil came out. the guy used it to lubricate the o-rings.
So, probably some will come out when I disconnect the existing line, so like you advised, I will have pag oil. That is good.Now, it leads me to another question. Do I need to buy pag oil anyway to replenish what I will lose?
Thank you!
Old Jun 12, 2022 | 08:12 AM
Seems you are looking for the cheapest way to do this.
Good luck.
Stonecold316
Sep 27, 2021 02:53 PM
rickpaulos
May 16, 2021 05:35 AM
Steven Rivas
Oct 21, 2015 12:02 PM
oldschoolcivic
Dec 9, 2009 11:23 AM
honda95_ract301
Aug 11, 2007 02:36 AM
