A/C Service Bulletin 96-012
Old Feb 2, 2015 | 05:37 PM
AnAmericanNCO's Avatar
Default A/C Service Bulletin 96-012
Does anyone know what Honda Service Bulletin # 96-012 refers to as to the first step to get accurate readings when doing a performance test of the a/c system ?
I've suggestions that it could be either of the following :
check the a/c system on low side w/engine at 3000 rpm, measure outlet a/c
temps at corner vents, connect r-134 recovery unit and/or mover the vehicle out of the sun.
Old Feb 6, 2015 | 03:12 AM
if you google the service bulletin, it will show you what to do. put the car in a shade and allow the car to cool off, keep all the windows up and run the a/c at 1500rpm turn on a/c and select recirc, run the blower on high for 15 min. then do the test.... Do you have a test system???
jad7984
Oct 7, 2009 01:52 PM
sidearm17
Jan 6, 2007 05:19 PM
vacuuum
Dec 29, 2006 04:45 AM
ss96dcm
Nov 28, 2006 10:08 PM
Prince
Jun 16, 2006 02:45 PM
