Can I remove air conditioner hose?
Old May 22, 2009 | 06:52 PM
ricosuave55's Avatar
Default Can I remove air conditioner hose?
I need to remove this air conditioner hose in order to pull out the alternator on a 1998 accord vtec 3.0
Is this hose pressurized, and will all the freon come out if I unbolt the lower end where the alternator lies?
Old May 22, 2009 | 07:51 PM
welcome to the forum. you should not have to remove the a/c hose which is pressurized. Do you have a service manual to replace your alternator. If you intend to do more than replace your alternator in the future, it would be a good idea to get a service or repair manual. and yes all the freon will come out and not a good idea.
will look into more info.
Old May 22, 2009 | 07:55 PM
Default thanks for the info!
It appears that the only way the alternator will come out is forward towards the radiator. I would have to remove the fan bracket and wires to make room...but the hose still is in the way of it moving forward?
Old May 24, 2009 | 07:48 PM
by removing the radiator fan, the alternator can come out the front. do not disconnect the hose. caution, do not ding the radiator either
CrossCountryDriver
Aug 29, 2014 10:35 PM
tleonard
Jul 31, 2009 02:41 PM
stephe
Oct 20, 2006 03:27 AM
h.fork
Oct 5, 2006 02:27 AM
barley
Jul 27, 2006 09:11 PM
